5100 question
gfluff
Member
At full droop, do your upper arms hit the springs (with 5100s installed)?
I ask because when I did the bils, I also did a 1/4 inch top plate spacer, but i think I don't need them. I went from 1.75 to 2.5 on the bils today, and got more than just 3/4 inch of lift, more like an inch and a half. Now the truck's a little nose high. Weird? Regardless, it's a little too high, and I think the spacers can come out without issue...if tha arms hit the coils (without spacers), my spacers aren't helping add droop....
I have LR UCA, no front sway, 5100 set at .85, eibach springs and toytec top hat and my UCA hits the spring at full droop
i have 5100's at 2.5 with fj springs and stock ucas, and at full droop i have less than 1/8" of clearance, between the uca and coil, but i am not running as much lift as you or [MENTION=55855]zopperman[/MENTION] are
Yeah I also have the LR UCA which allows more travel from the UCA.
charlesz
