Reviving this thread and people here probably have a different set up now but wanted to get some more confirmation.
884 and 2884 are the same, correct? I’m looking at this
https://www.summitracing.com/parts/emu-2884/make/toyota/model/4runner/year/2022#
I’m also thinking of doing the same set up:
Billies 5100 all around with
Front coil spring: ARB OME 2884
Rear coil spring: 1.5 (36-281817), potentially with additional .5 spacer (total 2”) for slight rake.
Some websites claim you’ll get a 2” lift like YotaMafia, Toytec, others say between 2.5-3” when set at the very bottom clip with the OME 2884. I had to do some more digging.
After speaking to a mechanic today, whom who installs these on a regular basis, he said 0 clip will give a 2” lift approximately. He suggested setting the clip to the second at 0.85 with OME 2884 on a stock weight 4runner. The lift will be between 2.5-3”, depending on the front weight. He also suggested on that 0.85 clip set up vs using a top spacers because the ride would be much stiffer. At 0 is recommended so you’re not pre-loading but 0.85 wouldn’t hurt for normal driving. Going above the 0.85 clip is not recommended specially I was doing a lot more off-road because I would put a lot of strain in the front axle. So I should be safe since I’m doing 99% pavement. He said the only thing is with the 1.5” in the rear, the car would be leveled if set to the 0.85 clip. And when the car is fully loaded, the rear would sag (reverse rake) so he suggested to either go with a 2” coil spring on the rear or a 0.5” spacer. I already have the 1.5” spring in my possession so I’m just gonna buy the spacer for now. Don’t want to buy the coil spring and shave another $200-300.
Anyways, I’m considering his recommendation. But love to know if people have the same set up with the new latest 5th gens.
