5100's set @ 1.75 with 1.25" spacers on SR5 with Hankook 265 Tires
Curtamous
I just had my 5100's (1.75") and Spidertrax (1.25) spacers installed on my 2WD SR5. Now this (I feel) looks much better than the .85 setting.
Motivation / Result: Leveled, Reduce Nose Dive & Body Roll / Excellent with all 3!
Measurements below.
If you want an All-Terrain tire in the 265 or 285 size, consider the Hankook DynaPro ATM's! I had these on my Taco and now the 4R. Cant say enough good things about these.
Here are some quick pics. Will try to post better at another time.
Measurements: (with full tank of gas)
Before-
LF: 33.3/4
RF: 34 1/4
LR: 35 7/8
RR: 36 3/4
AFTER-
LF: 35 1/2
RF: 35 7/8
LR: 36 1/2
RR: 37 1/4
Thoughts on look, stance, spacers?
Looks 100x better than stock man. I used to have the same setup.
I found it to be level most of the time, but there is that rare occasion where the front will be a hair higher than the rear depending on the surface you are parked on.
It looks good to me. Finally a sensible setup for everyday use. I would probably not use wheel spacers mainly just to keep the tires tucked in to keep from thrownig mud, rocks,tar, slush etc. on the sides of the 4runner.
I would measure from your rocker panels, behind front tire and in front of rear tire on level ground for true measurement to see what rake you have. If I did 1.75 I would have done a 1" rear spacer minimum...IMO. If you think it's great..that's what matters! Enjoy!!! Nice tires!
Looks good to me!
Nice choice on tires too! I'm running the Hankook MT's and cannot say enough good things about em!
Nice set up running almost the same thing. Set the 5100's at 1.75" added a 1.5" rear spacer and running the the 275/70/17 Hankook MT's.
Jesse1
