5100's set at .85, pictures
I finally installed my 5100's with fj springs this weekend. I decided to go with the 1.75 setting. I'm very happy with the results.
do you have any pics?
I ordered mine today, (back ordered until mid May) and plan to set mine at 1.75".
Mine is a 4x4 v8. Which gives less lift with the fj's.
OP sorry to threadjack.
I have FJ springs and 5100s set to 0.85. Back when I first did the install, here are the measurements I recorded (with stock tire size, 265/65/17):
Before/After/Net Lift
Front Left: 84.5cm/88cm/3.5cm (1.38")
Front Right: 84.7cm/88.5cm/3.8cm (1.5")
Rear Left: 90cm/92.3cm/2.3cm (0.9")
Rear Right: 91cm/92.5cm/1.5cm (0.6")
I've since upsized the tires slightly to 265/70/17 so the truck sits maybe an additional 1/2" off the ground. Here are recent pictures:
The lift is fairly mild but I like it; off-road capability is increased with ~2" additional ground clearance under the front axle which is desperately needed, but at the same time the lift isn't high enough to severely affect center of gravity and on-road handling (and let's face it, most of the time we drive on the pavement).
charlesz
