Apparently the ome spacer only works with nitro oem shocks tho, I order bilsteins, 885s and toytecs 1/4th inch spacers. Hopefully the front will give me 2.5 to 3 inches. Probably going to have to bite the bullet and get spc ucas also. Went with superflex and bils in the back and the ome rear spacer for driver side lean. Did I do good? [emoji16]Then the 885's are the way to go. But I would still suggest the OME recommended spacers instead of the .85" notch. One is a proven deal but I haven't seen any feedback from the other. And the springs still won't bottom out with spacers. You'll hit the upper bump stops before that happens.
Sent from my SM-G935V using Tapatalk
