5th Gen Front Diff Mounting Bolts
paczowski123
Alright so I have searched high and low for the bolt thread, length for the front diff mounting bolts. i have a diff drop installed that I am considering removing due to some noise I am getting and seems some folks experience these noises with diff drops, however, I do not have the factory bolts anymore.
Does anyone know either the part number for these from Toyota or at least the thread pitch/length for them? Online Toyota parts websites seem useless.
Just use the dif drop bolts you have, cut an inch off or put the spacers under the bolt head until you get the right ones. You could remove one of the dif drop bolts and take it to Home Depot or, other store, and match up the threads and then buy shorter ones.
Toyota uses high strength bolts just about everywhere. Home Depot sells weak Chinese junk. Better to go to an industrial fastener store instead of Lowe's or Home Depot.
If i remember correctly the shank on the bolt is longer not the threads, so removing the bolt and cutting down would just remove the top threaded section. If I cannot locate the correct thread pitch/length I may be just removing it and taking it to a hardware store.
You can match the bolts/diameter/threads, etc. just make sure you get grade 8 bolts.
tuṣṭāva
