5th Gen LE JBL w/ Nav - works fine but I'd like more bass. Add sub? Upgrade sub?
dauphin
Please keep in mind that the JBL system (w/ Nav) seems to be VERY different from the stock system (e.g., ohm ratings, crossovers, integrated through the amp rather than coming from headunit, and more.). Also, the 4th gen used a different JBL system so I'm not clear that the threads I found for the 4th gen JBL upgrades/mods are all that applicable. But I can link them here if desired.
This post is pertaining to the Limited 5th gen (2011) JBL system (with Navigation). In more cases than not, the forum threads here described JBL w/ Nav audio system modifications as being an all-or-nothing endeavor (replace speakers along with headunit).
To be honest, I'm fairly happy with my JBL system and the sound. But blasting the bass is a stress management tool that I've depended on it more and more since COVID :bounce:. The JBL sub isn't lacking, per se. Just - if some is good, more is better, right? I just want a small step up in terms of thump. And I don't want to have to overhaul the whole system.
OEM audio sells these JBL-Equipped 4Runner Systems - OEM Audio Plus products (complete speaker/sub replacement for 3K, or an "enhancement" (sub replacement plus amp and wiring harness) for 1K. It appears the enhancement is a replacement of the (?) 6" JBL sub for an 8" sub (but entails pulling and sending the enclosure to them, so... more $$$ ugh). Unfortunately, 1K is well out of my budget at the moment. Additionally, a local car audio installer gave me a (ballpark) quote of nearly that much for both labor and components (12" sub and custom box). For what it's worth, they recommended using a boxed sub and said that I would have to disconnect the JBL OEM sub. I don't really remember -why-.
I've seen these threads here, but I'm not clear on the outcome.
https://www.toyota-4runner.org/5th-gen-t4rs/266155-adding-mono-amp-10-sub-jbl-15-speaker-2.html
(User hasn't posted on forums since 2020 dadgummit!:doh:)
https://www.toyota-4runner.org/5th-gen-t4rs/287261-5th-gen-jbl-stereo-upgrade-build-diary.html
Same; no updates since 2020 (this one was doing a complete overhaul including headunit BUT he's got a lot of data on what WAS in his JBL system).
This post: https://www.toyota-4runner.org/2310234-post20.html from this thread: https://www.toyota-4runner.org/5th-gen-t4rs/114344-5th-gen-jbl-stereo-warning-those-upgrading-speakers-but-keeping-head-unit.html APPEARS to give some helpful advice except a lot of it is kind of vomited out without explanation. AND it is also 6 years old - are there any things that would be done differently after 6 years of technology upgrades??
I'm a DIY car audio newbie. Because keeping cost down is a priority, I hope to do a lot of the installation myself but depending on the suggestions offered, I may need a little direction at times on what to learn/read up on next!
A final note: A sub box has been suggested but I have a third row. Finding a sub box that will fit in the very limited space between the third row seat (when it's up) and the hatch seems like another layer of challenge that I'm not sure I want to tackle. I usually don't use my third row seats anyway, but IF I were to need to use them for some reason, I'd like to be able to temporarily remove it fairly easily.
Anyway, TL;DR or summary of the question is:
1) Would like to increase bass on existing JBL w/Nav system
2) Keeping cost down is a priority
3) DIY-newbie friendly is a plus (not required; but I might need some guidance or direction for further study)
4) IF I do a sub box, is there one that will fit behind 3rd row or should I get something with quick disconnect connectors?
Final note:
For what it's worth, I called Crutchfield to ask what might fit my requirements AND budget and they recommended
This sub box:https://www.crutchfield.com/p_575P50012P/Rockford-Fosgate-P500-12P.html
Or this one: https://www.crutchfield.com/p_575P30010/Rockford-Fosgate-Punch-P300-10.html
Any difference of opinion on this? And is this an install that a relative newbie could handle? If I -don't- have to disconnect the JBL OEM sub, then I'm pretty sure the 10" sub will be fine. I can afford that one a lot better than the 12". :ohwell:
What I recently did, was replace the stock 8" sub with an Alpine S-W8D4 and threw in a Sound Ordnance M350-1 amp.
Total cost under $350, 0 cargo space loss. Bass increase of a lot. No, not like a 12" with 500 watts, but a whole lot more than stock. Resonance is the biggest limiting factor. I have put sound deadening on the sheet metal behind the stock box, covering the stock box, and inside and outside of the cargo area plastic cover, but the plastic cover still rattles when turning up the bass knob. I might add some aluminum structure to the outside of it to stiffen things up.
I like the price point and I think I could be happy with a "bass increase of a lot" XD.
Can I ask a few questions about "how?"
Confirming that this is the product you mentioned:
Amazon.com: Alpine S-W8D4 S-Series Subwoofers : Electronics
It sounds like you mounted it in the stock sub location. Did you have to do any modifications to the enclosure like ARK_SWAMP_RIDER did, here? Because I thought I read that the stock sub was about 3" mounting depth but this Alpine speaker has listed dimensions of 3 3/4". https://www.toyota-4runner.org/521509-post1.html
Second - where did you place the new amp?
Third - can you walk me (generally speaking) through what I would need to do (I've never done car audio modifications before)? For example, where did you connect to the audio signal? I assume you left the stock amp in there to run the other speakers....
Thank you!
You could start with upgrading the stock sub, however it's still going to be limited in power by the stock amp
Agreed. Seems like it's going to entail sub + amp or it's not going to produce much of a difference. According to ARK_SWAMP_RIDER's post linked above, the stock amp puts out about 90 watts. A 350 watt amp like Jeremy556 mentioned is a significant step up, isn't it? I'm willing to go that route but...I still could use a hand with the "how-to."
DAMMIT I forgot that ARK_SWAMP_RIDER's vehicle was a 4th gen. So his specs (e.g., watts, dimensions) don't necessarily apply.
EDIT: This post seems to detail the methods but it's about 50% greek to me. Hoping the Sound Ordnance M350-1 has speaker level inputs????
Thank you!
That's the sub I got.
Only modification to the stock sub box I did was to install rivet nuts for the screws I used to secure the sub. Plenty of depth, didn't have to shave any plastic or anything like in that post.
I put the amp under the passenger seat, tons of room and the amp I used is tiny. I already had an aftermarket head unit, so I used its pre-amp sub outputs. With stock head unit, you will need a converter from speaker level inputs, or an amp with speaker level inputs.
Fortunately, when you take out the rear cargo side panel you have great access to the JBL amp and it's speaker level outputs to tap into.
I left the stock JBL amp to drive the rest of the speakers, may upgrade it in the future
ghengiskhan
