5th gen PS fluid
JLTD
So along with all the other fluids I like to do a siphon & refill on the power steering fluid periodically. Would like to do a little brain pickin' here for those that've got a bit more technical savvy or have already done this --
Previous gens allowed/specified transmission fluid to be used for the PS, but I see a different spec in the manual for my '15.
Any harm in using trans fluid, assuming I can get all or most of the old fluid out? My thought is that it is a hydraulic fluid with cleaning properties yadda yadda.
Appreciate any insight/experience/commentary.
What does your '15 manual say? The owner's manual for my '19 says:
"Automatic transmission fluid DEXRON® II or III"
ETA: I just wish there was some available out there without the red dye like the factory fill stuff.
Thanks for all the replies.
"Automatic transmission fluid DEXRON® II or III".
Mine says the same, apologies for not expressing myself well this morning.
I'm leaning toward using the same transmission fluid as used in the transmission...rather than the Dexron version. Since lots of folks are using the M1 fluid as Waco stated, I'm thinking that any transmission fluid that's good for the transmission would be ok for the PS pump as well.
When I changed mine at 75,000 it was reddish brown anyway so the dex 3 I used matched just fine :thumb3:
I would not use Toyota WS transmission fluid for your PS if that's what you mean. The stuff The Waco Kid posted says "Recommended by ExxonMobil for use in applications requiring Dexron III". DEXRON is just a trade name for a group of technical specs of ATF.
I've used Valvoline MAXLIFE ATF in both trans flush and PS flush.... been well over 30,000 KM's (18-ish k miles) now. No issues :)
I am currently in the process of replacing my PS fluid via the turkey baster method, aka siphon as much as you can then replace.
Using the same Schaeffer Oil as per transmission, seems to be improved so far after 1 cycle, with lighter steering feel and no leaks.
Using the same Schaeffer Oil as per transmission, sems to be improved so far after 1 cycle, with lighter steering feel and no leaks.
1. siphon as much as you can out of reservoir
2. add fresh fluid
3. disconnect the top return line leave bottom one connected
4. shove a vinyl tube that'll fit into the black hose as far and deep as you can
5. while vehicle engine is OFF but key is in ACC turn the steering wheel all the way left
6. while holding the steering wheel farthest left, turn the key on for 2 TWO seconds (this will pump out a buttload of old fluid
7. add more fluid to reservoir
8. repeat steps 5 and 6 for turning a full RIGHT
9. observe clean bright red fluid
10. get paranoid about the clicking sounds you'll hear as the PS pump works out the air in the lines
11. post about it on 4runner forum
For those who just sucked the old fluid out and refilled with new fluid, did you rotate the steering wheel in both directions a few times to push out more fluid in the lines or is that not necessary?
Is there a bleeding process for this or simply suck out fluid and replace it. Make sure the fluid level is at the appropriate hot min line?
I replaced my fluid with Valvoline Dex/Merc ATF Fluid,Dexron II and III compliant. I lifted the front end of the vehicle slightly so I can easily turn the steering wheel. Used the turkey baster method. I little time consuming but everything worked out great.
There is no bleeding process that I'm aware of.
Excuse the watermark. (Just thought it was strange you mention "red".
Use it in all mine for years without issue.
This is how I plan on doing it: Absolute BEST Method To Flush Power Steering Fluid!! - YouTube
Here's my fluid guide: Beginner Fluid Maintenance
The first time I did the turkey baster I cycled the fluid by winding the wheel a couple times. I did this 4-5 times and only used about 1/2 qt. It is time consuming. Sucking out the res only gets 3-4oz. I could have pulled the return line but didn’t have a way to plug the res at the time.
Since then I just suck the reservoir every time I change the oil. Working well so far. I use the M1 Dexron III but I would have no problem using Max-Life. I’ve finally used a qt of fluid over the past 4 years.
Update for anyone that's interested.
I double checked the fluid I'm using, and it's Dexron 6 compatible....after lots of reading, Dexron 6 is supposed to be backwards compatible with 2 and 3.
I did another drain and refill over the summer, and last week did 2 more. Each time it was a short drive to get turns lock to lock and circulate as much fluid as possible.
Smooth like butter now. No leaks.
I'll repeat every 25-30k miles from here on out.
MMJR_T4R
