5th tire?
mcarey86
Was just wondering, how many of you guys have matching spares?
I'm thinking about getting 275s in place of my stocks. If I went that route, obviously my spare would be 265. This is obviously not ideal.
I got a matching spare for peice of mind but it was by no means "needed". If you are sticking with a street tire and/or do not go off road much I dont think it would be worth while. While the offroading I have done is nothing world class I finaly was in areas that I was glad I had a set of offroad tires and was much happier knowing that If I had a flat I could not repair that my spare was just as aggressive as the tires that got me to that location.............it also looks nice having a meaty tire under the back vs stock.
I think that my plan will be to eventually get it, for many of the same reasons you listed. I'll likely start with 4, just to not slamdunk my bank account like I've been doing getting into this car.
There are some older posts discussing just how large of an increased tire size would fit. I have 5 255/80s, and the larger diameter tire (than stock) fits just fine. Some members have gone with 285/70s on the ground, and a 255/80 as a spare due to the decreased width and increased ground clearance. If you don't have or aren't getting a lift, this doesn't really apply to you ;)
I no longer off road aggressively any more so don't see a need for a matching spare. I run duratracs 285/70/17 . If I have a flat I can make it to a tire repair place on the stock spare just fine. For me to spend the $$ on a matching duratrac wouldn't make a lot of sense. The wider tire would just hang a bit lower anyway and I prefer the spare to be out of site.
All 5 matching...all bought at the same time.
Matching spare. With E load crazy ply tires, if one goes it's going to go someplace gnarly. $180 bucks for a matching spare is cheap compared to extraction services in some of the places I go.
I have all 5 matching, 285/70/17 Duratracs... If I end up on a trail that I'm concerned about the clearance of my spare underneath, I take it out and toss it on my roof rack.
Didn't you know your spare was mounted there to protect the lower part of the back bumper - and negate the need for a roof rack.
Well, I imagine there are other reasons for the spare to be mounted there, but I could care less about my rear bumper being damaged as it is plastic, and I've been looking to replace it anyway. Also, I'd rather have a scarred up bumper than a flat spare, if I were to smash it off a sharp rock or something.
I've was lucky with my first set of larger tires and only had my factory spare(never had to use it). When I decided to replace my first larger set, I kept the first set. I now have extra larger spares. I had destroyed a sidewall on one recently and was happy I had another matching spare at the time although, I still wheeled on it for two days with seven plugs in the side wall. Now I have two extras that I bring along on my trips. You can get away with running a slightly smaller or your stock size if the need ever comes.
I thought about the same when I bought my tires. Ended up just buying 4 and keeping the stock spare.
I actually just removed the spare from the truck altogether just to drop the extra 60 pounds or so for my dd'g. I figure new, E-rated, 3-ply sidewall tires should be less likely for a flat on pavement. Easy enough to throw the spare back on for trips.
Curious, how many have actually needed/used their spare?
chasebradshaw
