5vz-fe injector resistance question...
D'arce
I sent a set of injectors off to be cleaned without first checking resistance of the injector. I just got them back in the mail and when I checked them they tested at 13.9-14.0. I've seen where they should test around 14.4-5. I pulled them from a motor I had sitting that did run (99) and planned on putting them in an 2003 Tacoma. From what I saw it should be the same injector. I did post this in my Tacoma Rescue thread on TW but thought I'd ask here as well. Did I blow the cash on bad or worn injectors?
The factory service manual calls out 13.4-14.2 ohms for the range. Add a couple tenths of an ohm for measurement leads and you are right in range.
-Charlie
erinobr2000
