6'10" height limit
boxxer
I have a height limit of 6'10", I have '06 V6 sport. What suspension and wheel options do I have? I would like to also have a low profile rack but this isn't critical.
What is the stock height of your Runner? If it's is 6'5 I'd say you should go with 4" or less of lift (1" of insurance). Simple math really, just give us a starting point to work with and you'll receive many bias lift options, haha.
I used to live in a condo complex with underground parking, height limit was 6'7". My truck has a 3" toytec kit on 33" tires, and a rola rack on top of the stock rack, which is at least 2-3". I cleared the 6'7" bar by about 1.5". I'm pretty sure you'll be fine with any lift + rack at a 6'10" clearance. Just Do It!!! ;):
Yeah - measure the runner, its actually quite short. I forget exactly, but I thinkbits only like 69-72'' or something stock (depending on Limited/SR5/Sport). This puts it at only like 6' stock, giving you 9'' to work with on suspension + tires (again with 1'' insurance). Should be PLENTY. If you go higher than that, I'd be very surprised.
- Sent via Tapatalk for Android
I'm at about 7" lift (including tires) from stock.
I can clear a 7' garage door depending on the shape of the upper crest. If its flat then yes, arched then no.
Can't fit in my garage at home though unless i air down the tires :redbrick:
But its a good thing ;]
The only way to know for sure is to measure.
Lay a board across the roof/rack and measure to the ground. Do this in a few places on the roof.
Remember that if there is a dip or a hump near the low opening, you will need extra space.
spoiler highter than roof rack? thats weir.. or dont have the rack ? ahahhaha
Ha yeah, spoiler sticks up if you look at it.. If I remember it was very close between the spoiler and the highest part of the SR5 rack.
I was measuring because I only have so much garage clearance, and am deciding on a lift..
Measure FOR SURE !
I have 05 sr5 w/ OME Lift and I CANNOT Keep my aftermarket roof rack on and pull in the garage too Tall By about 3/4 - 1" !!!
patnewton
