That is a nice looking stance!
Thanks! I worked hard to perfect it. I tried a lot of different kits. It ended up being the simple method though. Throw on some springs and call it a day.. LOL
I find this confusing as well. Hopefully someone can shed some light on it. I think you're correct about the 14" coil on the king setup.
For reference my coils are 3" ID x 14" L x 700# with very little pre load
I attached a picture, you can just barely see the exposed threads above the collar at the top. Sorry about the quality. It's a blizzard today, I'll get a better pic later
What setup are you running? I'm going to be getting the Fox 2.5s and going with 650# springs. They also use 14" Eibach springs.
Radflo 2.5" extended travel without resi on 700# coils. Rear Radflo 2.5" no resi on Dobinson's C59-677V
Rest of my details are in my signature
After a little post stalking, are you running kings coilovers? How are they holding up in the weather, that’s my biggest concern.
Just wanted to post some numbers and pictures in case it helps anyone in the future. The springs are still new so maybe they'll still settle down.
But as of right now I'm running almost no preload on the passenger side. The lock ring on these Radflos forces you to have a quarter inch at least. I'm running one inch on the driver side. Radflo says in the installation instructions to not go past one inch of thread from top of spring mount to bottom of shock top with 700lb coils. So I'll go by that.
With nearly 200+lbs of weight in the front, I sit at ~22.5 hub to fender on the driver side. ~22.75 hub to fender on the passenger side. My stock height on the driver side at the time was 19.5 hub to fender. So that gives me 3 inches of lift and then about the same, maybe a little less, on the passenger since it was always taller.
I feel I don't have much room to play with height settings and that's fine. It's basically sitting how I like it. I gotta say though, it's never been so easy to play with lift. Gone are the days where I had to completely tear down everything to adjust height on my 6112's lol.
Hey nice ride. Was reading this and was a bit confused, you're running nearly a full inch difference in preload from side to side? I know some folks offset the driver side to compensate for the fuel tank, but a full inch seems dramatic to me. Have you had your truck up on an alignment rack yet? Just curious to see what the numbers show.
Also, I've got the same Radflo 2.5's with 700lb coils. I'm currently set at 1" of preload on both sides, just dropped it down from 1-3/16th".
From center hub to the fender I'm at 22.5" average. My bumper/winch/ light combo weighs about 200 pounds, I've got other stuff under the hood though, namely a dual battery setup, that'll add a bit more weight. Hope that helps.
I have no turns on the passenger side with the 700# springs and about an inch on the drivers to level out my ride. Hard to give dimensions since my stuff is a cut up, including fenders and flares.
Thanks! Same goes to you.
I guess technically, its about 3/4 of an inch difference since that lock ring is there using a quarter inch of space. But yeah, that's just how it's been for me really even after alignments with my previous 6112's. I just figure the gas tank and all make that much of a difference. No alignment yet but next week for sure. Now you have me thinking if that will change things up. I'll let you know when I get it.
I've got an sso bumper and winch going in mine as well. would you stick to the 650 or go 700. I want the best drive possible that stiffens the front and eliminated some nose dive but I do not want a spring that is too stiff. I'm looking to just lift my 4runner about 2 inches. I do not know anything about preload or how that would play a part
Jumping into this thread as a new 2022 TRD Pro owner (upgraded form an SR5 2WD) who has no real education on suspension. I am looking at the standard low-profile front bumper/winch/light-bar combo (offered by C4 or SSO) and have seen from threads like this that it is pretty clear I should upgrade suspension. Any good other threads or places to look at what it would entail? I don't plan to add a bunch, but ~130# slapped on the front makes it sound like even with the TRD Pro Fox Shocks, I need to do some upgrading. Any tips would be helpful as I start to figure out what I need to do. Cheers!
