[69][4K] Odyssey AGM Battery and GM DIODE Mod for higher Voltage for Proper Charge
But you lose the fuse...
I had that revelation myself and then did some searching. To this date, I have still not been able to find a single instance in which this has caused any problems.
I've personally been problem free for several years already.
The diode in the GM is only 1amp capable before it fails, while the fuse handles up to 7.5a.
You'll be fine.
I had to trim the diode to fit but it's in there and I'm getting 15.69-15.89v at idle off the stock factory alternator.
Littelfuse 02400104P 1A Mini Diode Automotive Fuse-4Pack
https://a.co/d/9X5xU1D
