7.5 q. oil into my '07 V8 - OK?
skipdup
Did the first oil change last night. I'm kind of surprised/worried that it took 7.5 quarts of oil.
I had a hard time checking the level - due to the clearness of the oil. So, I used a small jeweler's' file and scored the surface to get a better read on the level. I'm 98% sure I'm just at the high mark.
Has anyone else had to use that much oil?
Thanks,
Skip
Which filter are you using? A slightly bigger filter would explain the difference.
Even with the OEM filter, it will take 7 quarts with no problem, despite the manual saying 6.5.
Factory filter. Looked identical to the one I took off, except made in Taiwan vs. Japan.
If I'm within .5 q., I probably won't worry about it.
Thanks,
Skip
