85w140 in a transfer case
benztech82
Member
Hey, I got noisy engagement when in 4wd front shaft makes a quater of a turn and rear shaft almost a half a turn when putting in D or R so it seems like it compensating for a slack in a loose t-case chain with a loud clank. I'm thinking to use 85w 140 for a while until it granades or until I get enough money for a used t-case. Now the question, did anyone use 85w140 in a t-case for a long period of time or will this makes things to fail faster ?
Thanks.
Sent from my Redmi 4 using Tapatalk
I don't know if it will accelerate failure, but why would you put that spec fluid in there?
Just to dampen the noisy engagement, it would stop bothering me. If it drives for another 50k with this problem without making noises I would be happy.
What are you using in it right now? I'm running 85-140 in my front/rear because that's what ECGS recommended when I got my gears done but I haven't decided if I want to get away from the mobil 1 synthetic in the transfer case yet.
I don't think it would dampen the noise that much if at all, but maybe possible, but it could also make it grenade faster as well.
I think you should contact a remanufacturer and ask them what they think.IMHO
I used OEM gear oil last time that I did all of my fluids. Today I used 75w140 full synthetic mixed with some Lucas oil stabilzer additive like 250ml at most on the total of 2L of gear oil. I can't remember the brand of gear oil. I will take a picture tomorrow. So far it's less noisy. Also I didn't see any filings or chunks of gears etc when I drained the old fluid today, color wasn't too happy though, especially for only 10k since last oil change.
I’d like to see a video of this. Your actually not too far from me to take a look at this.
Based on your user name, are you tech? For Benz?
I used to be a tech for 10 years with Mercedes Benz Canada. Sure, I'm either in North York during the day or Mississauga after work.
