91 T4R 3VZE Crossover pipe install ? Possible ?
area1509
Hi all first of all I did search and search so here is my bone head problem.
Yes I had a ID10T moment in my hast to get the heads back on my 1991 T4R with a 3VZE I did not put the crossover pipe back in, is there a way to get it back in without pulling the heads?:cry2:
Yes it is :naughty: Just not with the heat shield ( I did header wrap the crossover)
We will see how long that works.
crossover pipe
yes it can be done. lower trans mount, remove bolts from fan shroud. may require someone to pull down on trans/transfer, while you are trying to route pipe back into position. p.s. exhaust manifolds might have to be loose. have done two header conversions this way(1st gen& 2nd gen). good luck and patience.
