'95 SR5 rear window switch not working
cgoodwin96
Hey everyone I have a '95 SR5 and my rear window switch on the center console doesn't work. My rear window rolls down only if I use the key. Also, for some reason, I can't switch to 4wd low, but 4wd high works fine. Also can't switch into low gear in 2wd. I have the 3.0L V6 with an automatic. If anyone could help me with any of these small issues, it'd be much appreciated. Thanks!
Your rear window could be a couple of things. It is probably either the switch itself or more than likely the relay for the rear window. Do a quick search on here and you can read about all the rear window issues and try to track it down.
Also go to this link to get the FSM for the backdoor out of my Drop Box. the file is 10 pages long. If it references you to a page not included, send me a PM and I will get it to you.
As for the 4wd issues I will have to let someone with a little more knowledge of the system but I would think you have a sensor bad somewhere.
This might be too late or just plain lame, but I noticed that the window lock button on the drive console will in fact lock the rear window switch just as it does the regular window buttons on the other three doors. I caught myself getting stressed when I thought my window stopped working....the lock button was depressed.
charlesz
