96-02 toyota 4runner front lower ball joint uniball spherical bearing conversion
First; I want to know who the heck is getting 100,000 or 200,000 miles out of stock LBJs? I did good to get 60,000 out of mine. I daily drive the hell out of it and off road/ overland with it on a pretty regular basis.
Second; I am interested in this product so I want to see what the engineering is. What material and grade is everything made of? tolerances?
I got over 160,000 out of my originals and over 200,000 out of the replacements (OEM). Coming up on 40,000 on the current ones (also OEM).
Have you had an actual failure? Mine had the original lowers at 162000 when I bought the truck. I probably changed them at 175000 after learning about the failures. I have no idea how the truck was driven before I bought it. But most of the true failures have been on lifted trucks.
Curious if the variation in longevity has to do with hard-core crawlin'/wheelin' vs plain ol' highway miles?
Most definitely. The extra stress of a lifted truck with bigger tires and putting it through hard terrain will certainly limit the life of anything on a truck, let alone the ball joints.
Yes the abuse of off road driving and bigger tires, but I think the big factor is the angle on the lbjs. In the years I’ve been on the forum most of the failures I’ve seen occurred while driving around a corner on pavement at slow speeds, and some of them had low miles on them. That’s not a high stress scenario. It seems the angle is what causes the problems even more so than harsh driving
What breaks when a lbj failure happens? The forged metal breaking or the actual stud breaking?
My 4Runner had over 270k miles on the stock ball joints... though, that's 2WD at stock height on the small 15" wheel package. Probably had 10k of off road miles in that time (maintained and unmaintained dirt roads). There wasn't any noticeable play in them when I removed them, but they were able to be moved more easily than the new OEM ones.
-Charlie
I'm all for the OP making this and selling. But I need proof. I need videos. I need to see other people running this. It's a little different then a company such as total chaos making this....
has anyone attempted to come up with a revised design of the LCA/LBJ in such a way that the joint becomes similar to those of the 4th gens? That way, the issue of catastrophic failure is eliminated
How much different are the LBJ on the newer gens ? What really amazes me. Is how fabrication companies have not stepped up and designed/tested a uniball LBJ
I came as close to failure as I care to get when my passenger side LBJ had enough slack in it that I could rattle it around before removing it. Since then I have always checked my LBJs when changing my brake pads and prefer to replace them around 50k miles. The reason I do this is because I drive between 40-50k miles a year for work and expo trips. Proper maintenance is cheaper than repairs or a ruined trip.
I've seen numerous 300k mile+ trucks beat to shit with accident history still running stock ball joints. They didn't look pretty, but they didn't fail either. They don't like lifts.
How the heck is the Uniball cup held in? Looks like it is pressed in from one side but is there a Circlip holding it from the other side? I don't see any welds either.
Yeah. Looks like it's pressed in. And one side is slightly larger in diameter. So it sits on the LBJ arm. Would be nice to get the seller on here. And share photos of everything.
Open for questions
There are many questions already raised in this thread, could you maybe read through the thread and answer them?
If its not welded in, how is it held together?
What kind of testing have you done with them?
What is your fabrication background/do you make them yourself or contract them out?
chasebradshaw
