96-98 vs 99-01 Replacement Corner Lights
I am 90% that they will fit, BUT Not all clear corners are equal. Some are more white then clear, looks like the more expensive ones are the actually clear variety while the cheaper ones are diffused and not as clear.
I think the diffused corners will look ugly next to your nice new retrofit!
How did you melt the corners? Just so that I dont make the same mistake when I do mine....
I put them in the oven and started working on something else and noticed a weird smell about 30 minutes later.... They were already a little deformed from the first baking (they are really small and not designed for the kind of heat needed to take them apart). If you have to take them apart I would set your oven to the lowest temp possible (mine happened to be 200 deg) and not leave them in there for more than like 3-4 min and just slowly work that them...
lindwlson982
