97 4runner overheated
GunslingerT4R
Last night before the sun went down I greased up my driveshaft and took it for a spin. While driving, she overheated and the check engine light came on. Got her home and put water in the radiator and unplugged the battery to get rid of the check engine light. Drove her this morning and I don't see any leaks anywhere. Does anyone have any insight on what I should look for or where to start? I don't k ow when the water pump was replaced but the radiator looks newish.
Sent from my SM-G950U using Tapatalk
Full on overheating? Mine was getting hot at low speeds and at lights. At highway speeds it was normal. My thermostat was bad.
Found the leak but can't exactly pin point it. Where do you guys think I should look
Looks like the water pump possibly the Thermostat area? I'm looking at my FSM and it would be one of those but with out tearing apart the front its hard to say hundred percent.
Mine had a leak from the water pump to oil cooler hose about there. But yeah, thats right over the thermostat. A bad head gasket leak would send bubbles into the radiator with the casp off and engine cold...
Hey, what 1911 is that?
Jon
Jon
It's one I'm building. Caspian arms frame and slide. Sniper gray and titanium.
CoaterZ_FL
