97 Limited 5 speed swap
Curious to see how much the plugs are different on the limited from the SR5.. When I swapped both were 97 SR5's and the II1 and II3 plugged right in with the communal wires having the same pin locations. Except for the STA and OBD wires which I had to manually move over to the ecu
I believe it is more of an auto vs. manual issue for him... (on the earlier pre-auto AC 4runners, at least)
-Charlie
I'll post the photos once, well, I do....
I've gone through the diagrams.
The sr5 manual doesn't even have the II2 connector. It appears most of the transfer case and locker wiring runs through it.
There were around 9 wires from the ECU variation to the body (H vs D plugs) of which 2 will come from II1 (STA and CEL).
There are 3 wires for the engine/NSS I will need to do something with, might attempt to re-incorporate the clutch switch and the clutch cancel switch in the II3 connector.
There are then 4 wires in the II2 for 4wd I will look into, 6 wires on the II3 for 4WD, and 2 wires for reverse on II3.
Since the II1 connections to the ecu plug are easy I decided to figure out the clutch switch and cancel switch.
Also turned out to be quite simple and most of the wiring is already in the limited.
The clutch switch bas 2 wires (white with a black line and black with a red line... will refer to them as W and B).
The clutch starr cancel has 3 wires (white with black line, black with red line, and black with yellow line... will refer to them as W, B, and Y).
The Ws go to ground. Tie them together and connect to a ground.
The Bs go together. Tie them together - these replace the A/T NSS system and you done need to do anything at the II3 connector. These connect to IG1 pin 22, which is where the NSS also connects (after it would have passed through the NSS, so you're basically bypassing the NSS). I will use a T-tap here.
The Y is a fused ignition connection that runs through the driver interior fuse panel. This is at connection 1F (which is at the bottom center) pin 2. It's a B with yellow line (imagine that). I will also T-tap this wire.
Connect your B to the IG1 wire and the Y to the 1F wire. This completes both the clutch switch and the cancel switch.
Good to hear. The auto to manual swap on my Camry required only moving 1 wire at the dash to engine harness connector, along with plugging in the clutch switches and starter relay. (along with the correct engine harness)
Good job on those spreadsheets. I didn't review them, but it looks like you know what you are doing.
-Charlie
Interesting....
Went to wire the clutch switch for cruise control shut off... and in the limited the cruise ecu wasn't where the diagram showed it.
Checked the SR5 and right there behind the center console below the radio... big as can be.
Checked the limited, then looked at the steering column... no cruise.
So apparently I have a limited without cruise control.
The only other things the SR5 has the Limited doesn't are the hitch receiver and rear roof deflector. The limited is a limited with the flares, leather, wood grain everything, locker, sunroof, was an AT with the push button 4wd....
I rarely use cruise especially in the manual 4runners, so I might swap, may not... just surprised.
I'll provide more info if it works.
I am pretty positive the wiring is done. Nothing needed for reverse. Repinned 2 wires for the transfer case, so the body (limited 4wd computer) receives the J shifter 4wd/low signals... and then simply jumped 2 wires at the 4wd computer to trick it into thinking the 4wd button is switched when the J shifter is put in 4wd.
Also seam sealed the welded center tunnel.
Now to get the engine back in.
Engine, transmission, and transfer case are all bolted in, started to do some of the connections and ran out of time. Seems to all fit well.
I lied, it does have cruise control. It's been a long week.
What's throwing me off is that the cruise in the limited is so very different than in the SR5.
The SR5 has what the EWDs call for, a dedicated computer below the radio.
The limited has a cruise control actuator that appears the computer is built into.
I will have to see what the options are.
Got some work done and, with the exception of II1 not being tight enough (I did it in the dark of night last night and must have gotten distracted) initial test fire worked flawlessly.
I did put the J shift into 4wd and then the light on the dash did kick on. I hit the diff lock and it just flashed, but there's no drivelines and the ebrake was set... so I'm not sure if it was actually trying or just yelling at me.
Once I get the radiator and belts in I can run a longer test.
Got the following done....
Front and rear shocks (new Blistein) swapped in
Front and rear springs (4th gen xreas, with only 100 miles) swapped in.
Not too happy with the 'lift' on the front- the Bilsteins do have the height adjustment but I don't want too much preload on the springs. Will see how it drives as is.
Wheels/tires swapped. Swapped a tail light.
Swapped all of the door (all 5) glass as the Limited had tinted that was turning purple.
Amplifier rewired and front compartments swapped with what I had in the SR5 (bigger MB Quarts)
Interior reinstalled using pieces from both vehicles- zero alignment issues.
Front driveshaft installed (PITA)
Still needs to go for a test drive. It does have a small exhaust leak.
However in the driveway all 4WD is working with the Limited electronic control, J-shifter, rear locker, and my wiring methods.
Those who tell you that you need a push button transfercase in a Limited are wrong. Wiring is actually pretty simple.
delislerebecca
