97' limited issue/question.
Deldonna
First off, hello to all! Love this forum, been lurking for a while, and have capitalized on the wealth of info and ideas.
I own a 97' limited, with a few minor mods, (toytec coil overs, ome coils out back w/ 5100's , tbu, few other minor things). This rig has never left me stranded, and I don't drive it that much. Recently I had the tell tale signs of a blown head gasket, (was still running at that point) took it in to a "reputable" shop, and had them preform the work. Both heads decked, cleaned, inspected & pressure tested. New timing kit, water pump, head bolts, gaskets, coolant system flush, t-stat, oil change, and a full tune up. Picked my rig up today, after they had closed, and now at idle it sounds like a diesel. The valve train noise is very loud. Any ideas what would make it sound like this? Is it normal due to "cleaning" everything? Mis-adjusted valves? I have already called and left a message, just trying to be a bit more educated for when I actually talk to the service manager. Thanks in advance for any insight offered.
Well for one thing, don't drive the vehicle. Have it towed back to the shop. Sounds like it might be eating itself [emoji51]
Could be anything, simple as a vacuum left loose or something serious. Might help to suggest them listen to another 3.4L vehicle if they think it's "normal".
Like a diesel?! Did you still drive it home?
Definitely nothing even close to normal after the work you had done- or any other time, for that matter.
It should be running like nothing less than a brand new engine, really.
If you could post a video of what it sounds like, we could give you a much better idea of what the problem is.
That being said, I wouldn't have driven it anywhere if it sounded like a diesel!
I guess your best bet is to just drive it back to the shop to have them fix it. Whatever damage has been done, is likely not going to get worse by driving it back.
Sounds like they forgot to put oil in it TBH.
Now that you've taken it, it may be a fight to get them to fix whatever has been damaged.
I hope they take responsibility for it, and don't give you any trouble [emoji1374]
I recently read where someone had the same exact thing going on after a rebuild, it turned out to be they didn't use a cam service bolt and the spring unsprung (or something like that)sounded like a diesel
