97 limited tranfercase wires
tylerwebbTR4
I'm needing so help via pics, I bought a 97 limited and the PO son some how ripped the transfer case out taking half the adaptor with it, and it ripped the wires out of the N and LR sensor connectors via harness side of connector, what I need is a pic of the connector gray and blue one and the wires that go into them and how thanks you can either post pics here or text them to me at (620)617-4759
If you have a simple soldering kit, I'd just go to a junkyard with a pair of wire cutters and cut off the connectors of a similar 4Runner. Solder up the same color wires, wrap it up in heat shrink or electrical tape and you're good to go. I had to break off an ECT connector once that had fused to the sensor and took only a few minutes to solder a new one on.
Why do you need a pic? Those are SPST switches--no polarity involved. Solder them back however you want to.
If you need a new connector housing, you can buy them for a few bucks. The part number is in the EWD for your year. If you have the old one, the number should be on there. A dealer, at least my idiot dealer, can't look it up but he can order it. I did it for my reverse switch I FUBARED pulling my trans to do the clutch.
You do better on here stating what your problem is and asking for a solution rather than demanding something that people are unlikely to have.
I'm really needing some help via pics, I didn't think that was demanding at all, connectors are still good the wires just got ripped out and I need up figuring out witch wires go to what connector and what side, and as for junk yards herd the crush anything import when it comes in, and no one in town has a Runner or Taco that I could crawl under to check out the wires
Don't those connectors have wires on both sides, one pair to the switch, and one to the truck harness? The colors are the same on both sides of the connector. Can't you just match them up?
See, I don't have pics but I can read an EWD and I'd be happy to answer your question if I knew what it was, exactly. Guessing you have the push-button T-case on a Limited, the blue connector (L4) should be on the right side and takes a blue-red and a black-white. With clip on top, looking at the female end, white black is on right. Gray one (H2,H4F) should be on the left and takes a White-black and brown-yellow. With clip on top, looking at the female end, white-black is on left.(Again, not that polarity matters here).
The one part I'm not sure of is the blue on the right, gray on the left part. That's hard to separate the 5-speed from the auto.
Does that match with what you have? Or are you going to wait for pics? (that need to be of an auto with push button because the J-shift auto and the 5-speed detection switches are totally different.)
As a bonus, here is a pic of a 2000 auto:
delislerebecca
