99 Limited lift question/help
Dkemp340
Ok so I recently purchased a 1999 limited that I was told had a 3 inch lift. Either way I figured it was a spacer kit. No big deal. I'll swap some coils in later. So here's my issue. He had receipts showing that the coils were replaced in March with Moog ST8595L then had a toytec 3" spacer on those. Also added 285's on the stock 16" rim's. The rear measures about 23 inches from the hub to the fender flare. Here's the kicker though, the front still looks stock even with the spacers. It measures 20" from hub to fender. I'm at a loss at why the front isn't lift more. Any help would be appreciated!
I have a 2000 with a 3" rancho, it is slightly higher in the rear but not a ton. Heres a pic.
