99 SR5 fog lamp installation
Here you go:
switch:
2000 TOYOTA 4RUNNER 3.4L V6 Electrical-Switch & Relay : Dimmer Switch Auto Parts
as for the lights, I picked them up on here in the for sale section. The kit number is:
PT297-89011
You'll also need the relay that goes in the fuse block (marked FOG) under the hood. You can go to the stealership or look for it online, my advice is online as the stealership in San Francisco wanted $30 + tax.
Part number:
90080-87010
Depending on your preference, you might want to change the bulbs...I went ahead and swapped them out for the PIAA 13556
Hope this helps =)
brain D you are the man! thanks for posting.. question those bulbs you ordered what color are they? cause im looking for amber color bulbs or leds to run in mine. to cut through dust bettter
i am installing factory fog lights into my 99 sr5.....
The fog lights i bought are used off someone on craigslist(lights tested before purchase and they work), i have the relay already plugged in(purchased from ebay 6$, i bought a new stalk with the fog lamp switch(new from rockauto), replaced the bulbs with correct bulb from xenon depot to achieve a amber color....
Okay everything is bolted in and plugged in as it should be.. the picture shows the white male plug with the pink and white wires that are already installed on the truck, the black plug with the black and red wire is the female connector that was connected to a matching male plug that is attached the factory fog lights. obviously the two plugs do not fit, so i simply cut off the white plugs and wired them myself(only two wires). after wiring them they do not work, no matter which way i wire, if the car lights are on, or off, even with the key turned to the accel. section.
am i doing something wrong, or is their a fuse for these little guys?
Help......
So, hopefully this doesn't sound condescending, but lets start with some basics. Make sure you're getting power to the wire under your front bumper with you low beam headlights on and the fog light switch on. Then work upstream. Could be some of the wiring is missing after the stalk switch.
Ok....update... I have no power at the wires for the fog lights. But I do have power at the relay spot for the fog.....what should I check next... I'm terrible at auto electrical......
I just want operational fogs
bump any t4r guys that are good with what im asking nearby long beach, ca? im seriously retarded with wiring. what should i look for next? or maybe im doing somethihng wrong
Copy! At first I bought one for a 2000. Which did not fit these things are model specific. So I bought one for my 99 and it fits perfect with its cool little fog light switch
This is the wiring diagram from the Factory Service Manual. Not sure if you have daytime running lights though:
