Jono.ful
#1 below
I have had my lower bumper cover (plastic gravel guard between stock bumper skin and my skids) pushed up into the a/c condenser while off roading on a couple occasions. At some point, the bottom inch or so has been bent forward about 60 degrees, and has been separated from it's rubber mounts so that it was hanging by the a/c hard lines. Obviously not an idea situation.
The system still blows cold air when asked, so it doesn't appear that I have a leak. Seems OEM replacement parts run about $700, and in reading the repair manual, one needs to remove the radiator to get the bloody thing out.
Anyone have a similar issue in the past? or experience with a re and re? By the time I get parts and an a/c gas recharge, this is going to be a hugely expensive ordeal.
