A Different Looking Oil Filter Housing Removal Tool
Lester Lugnut
It looks different to me. Unlike the Aussenmacher 460 or PBT 71113.
This tools is demo'd in the youtube video below. Fits the 2GR-FE housing used on 3rd gen Avalons and 3 or 4 other models.
Antman described the oil filter housing in his oil change write up as being plastic. Curious to know if this tool will fit the 5th Gen 4 Runner oil filter housing and if anyone has used it on that vehicle.
Thanks for your time.
https://www.youtube.com/watch?v=u0xW_zDGez4
It will fit the 5th gen 4runners if you have the 15620-31060 metal housing. If you have a plastic housing, you can replace it with the mentioned part number.
I don't think you can use it in the plastic housing, not sure if the plastic ears can handle the torque.
Thank you for the update on the housing part number. Yes, I too was concerned about the plastic wings breaking off.
My '06 Avalon came with a metal housing. Further proof that Toyota continues to cheapen their product line.
The Tundra guys use it on the plastic on in the Tundra all the time, IIRC it was one of those forum members that builds and sells them.
From TundraSolutions....most likely where this tool had its beginning. In this thread I saw the best idea of all so far. Lock Tite the oil drain plug cap; then use it with a 3/8" extension to break the housing loose. That part of the housing is useless. Let the engine cool down some; then remove the housing - tilt and let oil drain into a pan.
Tundra custom made Oil Filter tool
that part is not "useless"; when used properly with the provided plastic fitting, it completely drains the oil filter housing prior to your spinning it off.
i've noticed that it's the folks who fail to perform this procedure properly that most loudly proclaim "it sucks".
To each - his own.
I would have preferred it more if Toyota had kept the all metal housing that was used early on and ditched the drain tube instead. You're now forced to pay for a metal upgrade. I let my housing cool down which most would do anyway while oil is draining. After that it spins off and the housing is tilted and oil poured into a catch pan without any mess.
To each - his own.
"his own" meaning "the way it was designed to work"
and you're not "forced to pay for a metal upgrade"—you are electing to do so. in all the complaints, grievances and problems documented on this board, not a single one as far as i can recall has been that the plastic filter housing has failed.
would metal be "better"? sure. but the evidence doesn't appear to support that it's "necessary".
"To each - his own" refers to whatever a person chooses. It has nothing to do with design. If you like your little plastic gadget - so be it.
I am indeed forced to pay for a metal upgrade as I was not given one in the first place as was done in the beginning when Toyota introduced this approach around 2005. You said it yourself - 'Would metal be "better"? sure.'
Lester: i don't mean to pick a fight with you but i refuse to believe you're so obtuse that you don't understand my meaning.
"the little plastic gadget" is the way it was designed to work.
you are not "being forced to pay for a metal upgrade"—you are electing to do so of your own free will. buying a metal housing is no more compulsory than buying and installing a locking gas cap or a phucking burger tray—both of which "used to be" offered but are no longer.
this is my real beef: taking a small, relatively immaterial thing and conflating it with an nosedive in quality and a company in decline.
OK - I'm done. Enjoy your little plastic gadget.:bravo:
I don't mean this as a personal attack, but I am just curious, why do you feel that the metal upgrade is necessary? it is virtually the same exact thing unless you plan to exceed the melting point temperature of plastic (at which point you've got bigger problems).
Also, it may or may not be stronger against hard hits because those cast aluminum caps would inherently be more brittle and possibly even more prone to impact damage vs the plastic counter part. Not to mention nothing should be hitting that area to begin with unless you like to roll without the skids on. I've seen plenty of cracked cast aluminum oil pans in my days to know that it's far from indestructible.
Plus you have a better chance of galling the threads in the filter housing since it would be aluminum vs aluminum threads (instead of aluminum vs plastic). The bad part about galling the threads on the housing side is...well it's obviously not as easy to replace as a cap that screws on and off. If I had a choice at which mating surface I would want to be consumable, I'd pick the plastic cap any day of the week.
I've used both types of Toyota oil canister caps in my various cars and I see absolutely no advantage in the metal counter part besides the false sense of security of it feeling "tougher", lol. Realistically speaking, nothing is going to damage that thing unless you purposely try to break it.
Instead of wasting your money upgrading to a metal cap, why not just upgrade to a higher quality better fitting filter wrench? I have a beefy metal filter wrench that fits snuggly and can take off even the most stuck caps without rounding off the hex shape on the end. It's the cheap 99 cents filter wrenches with very poor tolerances that cause all these issues. As with most things, you're only as good as your tools :)
I do not see your comments as an attack.
The term "metal upgrade" should really be changed to "plastic downgrade".
I first saw this style of canister in 2005. It was metal. 2006 models had metal canisters as well and that continued for awhile. I now see plastic. So for me the issue is why did Toyota "downgrade" from metal to plastic?
If the metal upgrade isn't viable, then why is it offered with a Toyota part number?
Honestly, I am just guessing here, but that Toyota part number for the metal "upgraded" version, is it really an upgraded version for our 4runner specifically or is it from another model that started off using metal caps to begin with and it just happens to fit ours?
I don't doubt you in that it was probably a cost cutting measure, but IMO, I think there's better things to worry about. I really wouldn't sweat it...just make sure to not over tighten the plastic cap when putting it on; but if it makes you sleep better, change it for sure :)
In many applications changing the material spec to a specific type of engineered polymer is not a downgrade, it's an upgrade. Ex: Many of the guys run aftermarket skids and that's fine. If they really REALLY wanted the best skid plate ever they would switch to 1/2" UHMW polymers over a thin metal skid. Wear resistance is much better than steel or aluminum. This is just one example. Switching to a metal canister just to get rid of plastic would be the least of my worries for longevity. You gotta remember there are different types and grades of plastic just like anything else.
The discussion was between you and I - bringing my wife into it in the disrespectful manner that you just did is uncalled for.
don't get your knickers in a twist. i was just giving it back to you in a more humorous, lyrical way than you were giving it to me. and the remark was figurative; i'm sure your wife is a lovely person and that you're not half bad either.
i should've guessed that the guy who's "being forced to" buy a new filter housing is too uptight to take a joke. mea culpa.
in any case, sorry if you were overly offended.
Jhunt
