Hello All. I've been a 3rd Gen 4Runner owner now for about 4 years. I have a 1999 3.4L and I love it. Certainly not the most glamorous vehicle I have ever owned but at this point in my life, raising a family and saving for college funds, it's all about reliable transportation from point A to B.
I've done all the necessary repairs to keep this thing running for years to come with the exception of the dreaded axle seal leak. It's not that i haven't tried, I have certainly tried and tried and tried (3 times). The person I bought it from made a point to tell me that he did it DIY. After having it that first year I noticed it was leaking so I took it to a very reputable shop and decided to have the professionals do it. $1200 later I figured I was good to go. I didn't even bother checking to see if I was leaking because I was confident it was fixed but while doing my oil change about a year later.....I noticed the signs of leakage. Called the shop and they stood behind the work (even after 12 months) and gave it another shot.
Fast forward another 6 months and I am back leaking again. I found this thread and thought it was very interesting. I have a consultation back at the shop that has tried to fix it twice to see what my next move should be. I have a hunch they are going to suggest the axles are bent and I should replace them and try to seal them up again. I am not confident that is the end all be all fix.
Should I suggest they try the configuration mentioned in this thread? My other thought is, should I just bite the bullet and take it to a dealership. I'll spend the money. I'd rather throw another $1200 at a guaranteed fix to this problem than buy another vehicle. Spending the money to get it fixed sure beats spending the money it takes to buy a good used vehicle.
I guess my questions boil down to this. Should I give up on the independent shop? Is it a GUARANTEE that if I take it to a Toyota dealer they will get it right?
Any words of wisdom would be greatly appreciated.
Dude, what you need to do is take your truck back to them and insist they do the grease test right in front of you. This is what I did when my local Toyota dealership screwed up the job and I was leaking on my driver side in less than 5000 miles. The tech who did the job on my truck did not even know what a f#cking grease test was. So, another tech watching the whole show told him what he had to do. When he pulled the axle back out the grease test showed the lip of the seal was barely riding on the polished surface on the retainer, right on the edge of the bevel. At one point, one of the many techs watching what was going on told the tech that did the job on my truck that I just schooled him. This goes to show that a DIY mechanic can often know more than a paid mechanic because of forums like this that share information.
[MENTION=102606]infamousRNR[/MENTION], [MENTION=148218]JZiggy[/MENTION] and I recently did an axle seal job on [MENTION=148218]JZiggy[/MENTION] non-abs rearend. We confirmed without a doubt that following [MENTION=78997]Drcoffee[/MENTION] suggestion of flipping the retainer around was absolutely necessary to get the lip of the seal riding in the center of the polished part of the seal retainer.
What many techs still don't understand is they can't follow the FSM specs for the placement of the retainer anymore. Toyota redesigned the axle seal at some point in the past and now the lip of the seal sits 2mm more inboard than before. If you follow the FSM spec, the lip of the seal will be barely riding on the polished part of the retainer.
With the Non-ABS rearend, you have to press the retainer all the way against the bearing to get the retaining clip in place so you can't adjust the retainer position to get a better mating with the seal. The only choice we saw was to flip the retainer.
With the ABS rearends, you have a second inner retainer and an ABS gear. The inner retainer is what connects with the axle seal. This retainer in it's original orientation can be moved a little more inboard to mate up with the seal better but then it comes very close to rubbing the inside of the axle housing. Flipping the retainer again seems like the best choice to get a better mating of the seal and retainer and keep the retainer from rubbing the axle housing.
We filmed the Non-ABS job and we're going to hopefully film an ABS one soon. We missed filming an important part of the pressing procedure so we're going to wait until we film the next one so we can add that missing footage so the video will be complete and not leave people guessing how we did it.
TAKE YOUR TRUCK BACK AND TEACH THEM SOMETHING ABOUT OUR RIGS. Your efforts will hopefully avoid the next 3rd Gen owner that visits their shop for an axle seal failure from going through the same bullshit. Good luck and please report back what the result end up being.
