A340E to A343F swap
mmml4
Started the transmission swap today hope it doesn't take forever like everything else has. I am putting an A343F from a 97 Land Cruiser in place of the A340E. If I am successful I will be 4wd at last.
DSC02153.jpg~original
wow, for a second there i thought it wouldn't work but then saw your Solid front axle,
how much was this?
Empty tunnel.
DSC02915.jpg~original
Side by side comparison.
DSC02916.jpg~original
The oil cooler lines are routed over to the drivers side using 12 mm tubing instead of 10mm. Going to take the fittings out of the 2wd tranny and put them in the LC tranny and use my existing 10 mm hard lines.
DSC02918.jpg~original
The transfer case has its own wiring harness so that means I just need to get a pin out of the connector and build my controls to match.
DSC02917.jpg~original
Other observations,
* Swap kick down cables, LC tranny 's is not long enough.
* Looks like the park/neutral switch has the same connector and is in the same location.
* Same for the solenoid valve connector.
* The speed sensor is in a slightly different location but appears to use the same connector.
* The main shifter linkage is on the passenger side, looks like I will have to modify my shifter to come down on the passenger side as well.
* The 1FZ bellhousing on the LC tranny is about 40mm longer than the 5VZ bellhousing. I think this means that I will have to swap out the front pump, torque converter and I don't know what else.
Wish me luck.
Here is the 4runner tranny minus the bellhousing, torque converter, oil pump and overdrive assembly,
DSC02919.jpg~original
and the LC tranny,
DSC02920.jpg~original
Here are the overdrive assemblies, the one on the left is the 4runner and the other is the LC,
DSC02921.jpg~original
3 hours later, wala
DSC02923.jpg~original
DSC02924.jpg~original
Well if nothing else we know it will all bolt together, the real test will come soon I hope. I forgot to take pictures of putting the oil pump in, dammit it sucks getting old.
Just to clarify, I did have to swap the oil pump and the overdrive assembly because the LC shafts were longer than the 4runner shafts.
Well things were going great, I mean all the tranny parts swapping went well and I posted up on IH8MUD to get a pin out of the transfer case wiring harness and in 2 hrs I had exactly what I needed. I was thinking this isn't near as bad as I thought it was going to be.
Then I got home from work and started to put the new tranny in and found I am going to have to cut a large hole in the floor board to get that fat assed transfer case in. The 4lo/high shifter will have to be relocated because it comes up in the console under the radio, hells bells what was I thinking. :redbrick:
I'll be amazed if we still have the internal combustion engine by the time I get done. I have been accused of being a glutton for punishment, maybe they were right.
Now that I have to build a new crossmember I was wondering what would be the best way to get the engine at the right angle. I don't know offhand what or where would be a good reference point, anyone have any ideas or experience with this.
Made a little progress and yes it looks even worse in person. I figure enough seam sealer, paint and undercoating and all will be good. That was a real pain in the ass I must say. Still got to weld it out from below.
Going to replace the rear main seal on the engine and the front pump seal on the tranny before I go back in with it.
I also found the parts I need to control the transfercase, a nice Land Cruiser man in Idaho has a 97 parts truck. He has the wiring harness and relay.:thumb3:
DSC02939.jpg~original
DSC02940.jpg~original
I still got to fit the seat mount back in, yeah more fun.
The transmission will be ready to go in after I replace the pump shaft seal, swap out the park neutral switch/shift shaft from the 340E to the 343F and finalize the crossmember. I started a build thread here on t4r.org, it's in my sig. The finished product will be in there.
4Runna4Rumma
