About rear sag
I totally agree with you. I have a 2000 4WD and I installed the 99 coils all the way around with new Trek Master Shocks and the rear sags worse now! WTF! Did you notice any negative impacts from your rear spacers? Any strange rattles or noises? God know I have enough of those already I can't pin point.
Nothing negative at all so far. Finding rattles can be tough but I have a few methods to pin pointing them if your interested. http://www.toyota-4runner.org/showthread.php?t=49480&highlight=finding+squeaks+rattles
since i added my spacers in the back and front, it deinetely clicks alot more. I replaced the shocks and struts though and it definetely helped the problem, now just more minor.
Likewise own a 3rd generation (98) with impending butt sag. Was not able to get the customer service letter or the recall info from the forum site. Any chance you could shoot me a msg here or PM with that info as well? Would be greatly appreciated!! Thank you for your consideration!
Replace your rear coil springs with Old Man Emu 891's (model number). I just put them on my 02 and the improvement in ride and handling is great. I had done a 2.5"lift and starting noticing that the rear was slightly lower than the front, due to the saggy springs. I replaced the shocks all the way around, and the new strut shocks on the front lifted it up even more. Then it was suggested to me not to replace the rear shocks unless you replace the rear springs at the same time. So, I bought the rear springs from Old Man Emu ($150 for the pair), and the rear now rises above the front slightly, giving me the profile I wanted. If you don't currently have a lift, make sure you install some spacers on your front at the same time, if you go with the OME rear coils.
WHen I had my new rear coil springs installed, I heard rattles and noises from the rear, but after a day or so of driving, it has disappeared. I had 2.5" spacers, but removed them since the new coils give a 2.5 lift.
I replaced my coil springs with new factory springs and still had a sag. I just installed 1.5" Daystar spacers on the rear and now it sits level. If I had to do it over again, I would not replace the springs because it didn't fix a thing. That little bit of sag has a very negative impact on the ride and handling too. Toyota should correct the problem on all 3rd gens instead of limiting the recall to the first few years. I got the spacers for around $40 and installed them myself so it was an easy, inexpensive fix. Here's a pic with the spacers installed (Sorry, no before & after)
What's involved with installing the spacers ?? I'm thinking seriously of doing the same thing to my '02 T4R. Thanks
Lar.
Very straight forward install. I just had to disconnect the lower shock bolts, the sway bar end links, and the lower end of the lateral control rod to drop the rear and pull the springs out. The spacer just sits on top of the spring and the beehive type bump stop still drops right into the top of the spring too. I did have to use 2 jacks, one for the diff and one to lift at the frame, as well as a long pry bar for the extra 1/2 inch of clearance I needed to get the springs back in with the spacers on.
My install was very simple and straightforward - I paid Sears automotive $75 to install both of them. That included removing the stock springs and Daystar 2.5" spacers, and installing the new OME 891's. Here is how it looks now. By the way, if anyone wants the Daystar 2.5" spacers for their rear coil springs, I will ship them to you pretty cheap. They are not even a year old.
Butt Sag
Hey Guys... same goes for my 01 Runner. the Butt is starting to sag more so on the left side, looking at it from the rear, my runner is tilited to the left. In everyones opinion, what the best thing to do thats wallet friendly, spacers or replace the suspension and coils? And is there a way to make the ride a little softer? let me know, all suggestions are greatly appreciated. Thanks!
wow! Im going to print that out right now and go to the dealership. My 1997 has that problem. Do they just replace the coils with stock ones or what?
just wondering if anyone has done the fj80 front coils swap and how easy that was. Read on some forums that it gives about 3" of lift. Will I have to modify any other part of my suspension to compensate for that?
Got mine fixed under the recall today.
before.
b05726c7.jpg~original
after
9cbd539e.jpg~original
The ride is much better but I still need to do new shocks.
Great pics Collin! I'm debating over them not fixing mine cuz 1)it rides great 2)if it aint broke don't fix it(atleast on stuff u don't wanna customize) 3)would result in down time and I work 2 jobs = big inconvenience. Plus, look at my avatar pic, there is no sag that I can see! :thumb3:
before.
after
What did they actually do? From the pic it looks like you've got a new, shorter upper rubber dumper. Anything else?
Also looks like they slid a rag down to the spring, arent they supposed to replace the springs?
