Rear spring sag
Daryl Elmore
Junior Member
I installed standard strength lift springs in the back when I lifted my truck but now I have a drawer system and bumper with a tire carrier and the rear sits about an inch lower than the front. IT rides great but I hate the sag. can I get away with 1 1/2" spacers in back or is it better to go up a strength on the rear springs? I really don's want to stiffen up the ride, just make it more level.
Spacers will inherently provide a stiffer/harsher ride quality and I would not recommend them. I personally have had them before and for being cheap on price you get what you pay for. If you have the funds for a different spring setup, that's what I would recommend.
I have 10mm OME trim packers in the back... but that's only 0.4" or so - not what you are looking for. More than that will likely not really be what you want.
There are plenty of spring options for carrying heavier weight.
-Charlie
I have the ome 861, it's a stock length EXTRA weight spring +250lbs, it gave me a 5 inch lift! I'm thinking the 851 is what your looking for. It's the stock weight up to 110 lbs front lc80 springs.
I have a constant 320lbs, I added 360lbs of concrete and it only compressed the spring 1/2 and inch. I'm sitting at 25.5 inches hub to fender.
Old Man Emu - 2851 - Coil Spring Set
851, 861, whatever it takes. - Mr. Mom
:D
erinobr2000
