I am the owner of a 2004 Toyota 4Runner SR5 with 4WD and a V6. As you know the combination of ABS and dirt roads can be dangerous. In addition to this, it is also a proven fact that ABS system will typically not function properly with 4 Wheel Drive and a locked differential (this may not be the case for a center locked differential). I would like to ask the following questions about my vehicle based on these two facts:
1) When is ABS NOT Active? That is to say, is ABS turned off when the 4Runner is in 4WD LOW and the center differential is locked? Or 4WD High with the center differential locked?
2) When VSC is turned off is ABS also turned off?
3) If ABS is not turned off, how do I stop in a reasonable amount of distance on Dirt and Sand (other then crawling along at an unreasonably slow speed, which does not always guarantee safety)?
4) If ABS is turned off, will the car automatically still pump the breaks?
5) Does break assist (activated by quickly pressing down on the break pedal) still use ABS?
I ask these questions to better understand how to safely operate my vehicle under different road surfaces and conditions.
