ABS Disable Gone Wrong
rrlance
I finally decided to add a switch to disable ABS. It has caused me a few close calls on snow and ice. I read how to in this thread and decided to use the method in the last post of cutting the grey/red wire at the ABS computer.
My ABS light now stays on and never goes off. I checked the fuse, and it appears good. I also disconnected the battery for 10 minutes. I read on here how to get ABS diagnostic codes, and it showed code 31, 32, and 51. I'm clueless on where to go from here. Any advice is appreciated.
To be honest, your best bet might be to remove the switch and solder the wire back together and pray you didn't short circuit something in the process. If that's a power bearing wire and you didn't disconnect the battery when you worked on it you ran the risk of blowing fuses and/or other components.
DJNutshell
