abs trouble codes
blubill
I did a search but didn't find anything. Does anyone know what trouble code 31 means for abs? Or is there a place to find all the trouble codes so I can check for myself?
DTC 31 is your front passenger side abs speed sensor. I had the same code, bought a new sensor, replaced it, and all was back to normal.
Rock on! Thanks bud
Sure thing. Be careful when you take the old one out because it may be seized up. The problem is often that the o-ring on the sensor went bad and things started happening. I just used a big pair of vice grips to pull it out. Throw some grease on the new one too.
patnewton
