AC Outlets, just 1 on 19's?
ColtB45
I have a 19 TRD OR that has a single AC outlet in the rear cargo area. When test driving 4runners I was in both a 16 SR5 and a 17 SR5 that had a AC outlet inside the center console. My 19 TRD OR doesn't, just the one in the rear.
Was this a option I missed? If not, what year was it removed (18 or 19)? What would be required to add it back?
I do believe they removed it in 2018 and up. My 18 SR5P doesn't have more than the one in the back. Bummer.
Alright you made me walk out to my truck and look. I have a 16 TRD Pro and I no not have a 120V plug in or on the console. I do have 1 12V inside and (2) 12V plugs on the rear. They do have covers on them that says 12V 120W. Are you sure you didn't misread that to say 120V?
My 17 has 1 12v in the lower dash, 1 12 volt in the center console, 2 12v in the back of the center console, 1 12v in the rear cargo area and 1 120v/400watt inverter also in the rear cargo area.
[MENTION=303056]Bayou_Pro[/MENTION],
You are correct.
My 2014 has the same thing you have in yours.
There is only 1) 120V in these units, and that is in the rear cargo area!
This is the setup I had in my 2010 Canadian Trail Edition.
I prefer the 12v in the center console than the 120.
You are correct. I had the 120V in the console of my 17 GMC and never once used it. I did like the rows of USBs it had though.
I have a '16 Limited. I'm going to have to check the one in the center console. I thought I had a 12v. If I have a 120 there, I'll be shocked after all this time!
Suck it, losers! :D
I think I’ve used the front one once.
Ambrose67
