CanadianTRD
Allright... I got everything done today. Took me most of the day, part of the slowness was the kids running around and a movie run late in the afternoon.
Anyway, everything went pretty smoothly. I replaced the compressor, the expansion valve, condenser and drier. I did not get any pics cause it was hot and I was dirty. I did not want to take the time to wash hands to take a picture.
When I had the refrigerant pulled out, there was 1.87 pounds in it. A wee bit overcharged. Weird thing is what was in there is fluorescent green. Now its clear like it is supposed to be. No big surprises and the hardest part was pulling the cooling unit from under the dash, and even that was not difficult. I bought 2 12 ounce cans of Dupont Suva 134a and both cans went in for a total of 24 ounces. The high side of the recommended charge is 1.5 pounds and both cans puts me right there. I should have stopped before dumping the entire second can in, but something I did not expect was happening. I could not get the bubbles in the sight glass to go way. So after dumping all 24 ounces in, I read in the FSM that on very hot days, even a correct charge can show bubbles in the sight glass. It was 92 here today and I got the duct temp down to 58. Should be colder but it was hot and humid today. With idle at around 1500, low side is at 35psi and the high side goes between 180 and 250.
Aside from the initial cost of the equipment necessary to perform this work, I would encourage anyone else to work on their own AC.
Nice work! And even nicer pressure readings, those are better than factory lol
BUILT NOT BOUGHT. It's always more satisfying in life to DIY than otherwise, then you now know a new skill, and you can teach others too! Not to mention saving a boat load of cash that can be spent on proper toys :thumb3:
