Adding USB ports to '12 4Runner trail
ltsatch
I have two blank spots in my center console right behind the shifter, approx. 1"x 2". I would like to add two dual USB chargers side by side, no audio involved. These would be able to take care of the front passenger and rear seats. Has anyone done this yet? Searched the forums with no luck.
This is the area, trying to find a port that size.
2 Anker dual USB car chargers (1 for the front and 1 for the back will probably serve you better.
They are very slim and barely sit proud of the charger rim. They make versions that are high wattage.
That location has the tendency to attract dirt and grime and USBs don't really like that that much.
Also, when in use, the cables stick up and get bagged around quite a bit.
YMMV, just my .02.
Not as clean as built in USB ports, but a lot easier. One of these in the front 12V socket and 2 charging cables, one short, one long. I roll up the long cable in the back seat pocket to keep it out of the way.
YMMV, just my .02.
No 12v plug in the rear seat area on a 12' trail
Any chance you could add a picture? Did you wire straight to the fuse box? Thanks for the links. They look promising.
Yup, I installed an “add a fuse”.
did you have to do anything to make them fit? when you get a chance, pleas post a pic :bounce:
Just remove the blanks lol nothing special
BTW the photo distorted the reading on the voltmeter. It measures pretty close to what my voltmeter in the rear indicates. You’ll also want to add covers to the USB ports so you don’t build up dust and junk in them.
Awesome [emoji122]
BTW the photo distorted the reading on the voltmeter. It measures pretty close to whtat my voltmeter in the rear indicates. You’ll also want to add covers to the USB ports so you don’t build up dust and junk in them.
That size looks perfect, thanks!
Thanks to blksubykid I was able to get the correct usb/audio port for that blank space. After consideration, I am going to add the same port in the next slot because the Sony XAV-AX-5000 head unit I installed has two USB audio inputs, one for Apple Car Play, the other for Android Audio, they still work as chargers as well. Below is the link to the correct unit. Amazon.com: Cllena High Speed Dual Port USB Car Charger with Audio Socket for Toyota Series,USB Charging for iPhone, iPad, Samsung and More (3.3A + Audio)
Air on Board is a perfect fit. Switched out one of the 2nd row sockets and one on the driver side dash.
premiumusedautoparts
