Its not hard at all, just make sure you have the correct seals before hand.
You could also lock the slide collar in the ADD tube with a hose clamp, and add fluid capacity to your front diff and then you dont have to change anything out.
Can you share the part numbers for seals and additional parts I will need for the axle tube swap?
