A few updates on the taco:
1- the rear links are still holding up, the heim joints are taking some frequent lubrication with a dry lithium spray grease and wd40 but overall no big issues for a daily drive. The factory bolt is just a tad small for the opening in the heim spacers so unless it’s fully tightened on a regular basis it develops a slight clunk as you back up at certain times and the loading changes. I don’t really want to crank down too hard or put locktite on so I don’t have issues later so I’ll see if I want to live with the slight clunk sometimes or do something about it.
2- the Rcv axles proved to be prone to the same cv boot burping that the oem axles have wit extreme angles and articulation. The metal band clamps just aren’t tight enough and once a little grease makes it under it get progressively worse. I contacted RCV about installing my own worm gear clamps to overcome the issue and they said they would very much be ok with that and appreciated me taking extra steps to prevent possible premature failure. They did say that they fully stand by their axles and unless I go out of my way to destroy them that they would fully honor the lifetime warranty even if the boot ran dry of grease and the cv failed. That’s the main reason I invested the money into them so it was nice to get that reassurance once again.
3- the JBA uca’s have held up great so far other than slight wear on the ball joint boot but some regular greasing has kept it in great shape thus far. Not sure why I ever considered selling them in favor of the ICONs since those don’t seem to be any better other than additional cost. The ball joint being an off the shelf replacement seem appealing for when it needs to be swapped so we’ll see how it goes.
4- that lfd skid plate painted red makes for nice contrast, love it. But being a v8 I do need to drop it to change oil or put on /take off the front sway bar… for the time being I’ve been without the front sway bar for a while and it doesn’t bug me too much, but definitely would be nice to have for highway driving and on winding roads just in case.
