Affordable black wheels recommendation for 06?
scd969
I am looking for some black wheels to replace my stock on my 06 Silver SE. I really just want something that is matte black and will give me the same stance as stock plus spydertrax that costs around $100 per wheel. I won't be doing much offroading, maybe a couple times a year. I mostly will be using it for a dd.
Doing some research, I am thinking I need a 17 inch wheel, that is 8 inch wide, with a 0 or slightly negative offset to achieve the slightly wider stance. I'll eventually pair them with 265/70/17 wheels methinks.
Any recommendations on something like that? There are so many wheels out there that I am a little overwhelmed and want to make sure they will work for my ride. Thanks.
Check out the Pro Comp 7039's and if you get the correct offset you will not need the spidertraxx
Stock sport wheels powder coated matte black $35 each.
I boughtn17x8 black rock wheels for about 400 shipped. Alloy. They are my second set a(had them on my wrangler) and I love them.
Thanks for the tips. I'm looking at the Level 8 wheels currently, the Guardian and the Tracker look pretty cool and are around $115 each.
i just picked up a level 8 punch rims 8.5 -6 offset. if you get a neg offset you won't need to get wheel spacers. with this offset it is about an 1.5 further out and I'm taking off my wheel spacers. with the level 8 rims keep your eye out for wheel weight to keep mpg's down. extra weight and wheel spacers will defeat your price saving on rims in the long run. i think you should go with trd pros/ fn replica that sounds like what you need.
I wouldn't cheap out on wheels. I had a cheap set, they are usually heavy, and paint starts chipping away. either save up for quality wheels, or just paint your stock ones
I'm looking at 17x8 with -10,how would that do?
Are the Level 8's pretty light? I need to put her on a diet!
17x8 with a -10 is a 4.11 backspacing.
17x7.5 w/+30 is a 5.43 backspacing. oem sport wheel
if you add a 1.25 wheel spacer to oem its 4.18 backspacing
you also have to take the .5 in to the front rim for added width.
the 2 models of level 8 rims i looked at had a difference of 8 lbs. so it all depends what you chose. without the wheel spacer your saving another 5 or so lbs to the unsprung weight.
I need less back spacing and I'm not running spacers.
Looking at the MK6.
I just got the Level 8 MK6, and am diggin the look.
Nirv_IEajsc9JGstLQ7V2P1KWpGWiVnSvciAIj7Raq2ZAA-ykkr4nNfZfG86UwoL4V-pHZmJW2dYAa5Erxk7nw0cYHHq6Tz-3y_ONZJFCDR0lFDuaE-Cb7JsDFaWQ3t4Tv63y2ik0l-eYyzPdee07yjHX8ExkkMLyQ6kl_IxUymPaJF7xeKQC574R_pFS9_b2NpMAGX79p4E-8GcxFHEwubcgahcqw9_GRgv7GooN6TDDo3bgQ0ifDiNq2iClVEB4iv54xBuqzCYnr2VFtQSv7VKk9ePwVIJmeyZRmZN6C-tvvkwwyNhHlp9Oo-m0c5p3qWBnMiAUZ5LuKOwu0-HZQoISU1UX29nWnkoKOHCNdtAZY3GVwwhzYgYVyyEuwwfDw8ethsghepGGpRpagfjWL7xdkyiVlXqGSb60tUERhODWt2R8o3FCWmIubscnnZGoub_bfWD4Sh49tBAFQQ-kO16OA4kvTL1cUfX-ctjtvk0cxp-atqfjpIamCHifyLLoDKIm5DrKa1L1ogNsw3MZoVzuSnxVAq5WZz_qQZY9X3o=w1065-h599-no
