Affordable black wheels recommendation for 06?
So I am trying to do similar math with a set of Pro Comps (these)
If my stock rims are 17x7.5 +35offset (05 limited)
The procomps are 17x8 with 0 offset
Where will this put me with inner clearance and outer position?
I really don't want to run spacers since they are heavy and my experience with them has not been very good.
Can any wheel guru's help?
use this calculator
CCW - Complete Custom Wheel // Technical - Offset Backspacing Converter
it would be 10mm difference. backspacing is rear of rim to mounting surface and 17x8 /-10 would be like an oem rim with a wheelspacer. you have the look of a wheel spacer and it is safer and lighter. if you want to fit like oem then it will be around +25.
Thanks for the help. I have owned my share of aftermarket wheels, but they didn't use to measure rear spacing like they do now.
Crazy thing is I just plastic dipped the stock ones two weeks ago!
Yeah, that's why there was so many custom wheel place before and the numbers weren't given to the public. Now everything is online for us to get exactly what we want.
I was looking at the mk6 first and decided that punch were cheaper and lighter. It was 8 lbs lighter. I like the look better then punch and I didn't want to add more I un-sprung weight plus bigger tires. The mk6 weighed in at 29 and oem rim was pretty close. But the rims I'm running now are 24 lbs. heavier rims and tires makes braking harder and mpg loss. Just an FYI for people just wanting cheaper rims.
Got the MK's installed. 17x8 0 offset.
265/70/17
DayStar 2.5/1.5
Hey Dpassmore, the MK6's look great. I'm probably getting those or the Trackers but can't decide on the offset. (0 or -10)
Could you post a head-on pic and one from the rear so I can see how much more width you got from stock? Thanks.
I went with MB TKO 17x8.5 -6mm offset . Offset is perfect. Most inexpensive I could find that I liked. Got them from discount tire.
I liked the look better without the center caps
