Something is off here.....I don't think I've ever seen one sit like that. Are you 100% certain the rear coils are stock FJ's? Are the coils seated properly in the lower mount? The front FJ coils typically lift more than the rear, so I would expect less rake than you'd see with just the Daystar 2.5/1.5 kit.
Dude told me that they were off a stock 2008 FJ. And yeah, we double checked everything, everything is tight and seated properly I'm not sure which route to go, stock coils with the spacers or FJ coils with no spacers. I'm open to suggestions? I'm not 100% happy with how it's sitting
I believe fj springs are like 10-15% stiffer than 4runners so if you like it a little stiffer i would go with fj no spacer. If you like it ride like stock then go stock with spacer
+1.
I still don't understand how it could be sitting that high. Could you take some pics of the rear coils installed?
As said....those most definitely aren't the stock FJ coils. They have more wraps than any of the OME coils. I couldn't find any pics by doing a quick search of the All Pro 3.5" coils, but I really believe that may be what you have. Visually comparing the coil to stock plus your lift height you gained, the All Pro 3.5's is my best guess as to what they might be.
If I'm right, you really will need longer rear shocks as I'd expect the stock ones to bottom out easily. Even 5100's are really too short to be used with those coils (they would work, but not ideal). You'd also need extended brake lines to be safe.
It depends on your goals, but best bet is probably going to be using stock coils with the spacer. You can do some research to try to figure out what rear coils those are and maybe re-sell them for a good profit.
