Aftermarket or DIY cup holders?
fivegear
Maybe I am just to stupid to search properly but I tried every combination I could think of and haven't found anything.
Has anyone come up with a decent aftermarket or DIY cup holder for the early 3rd gen? I have read the console swap threads and may end up doing that but I would rather come up with something a little simpler for now.
Every time I try to use the pull out dash cup holder on my 97 I feel like strangling someone at Toyota :mad:
Thanks for any input on this :thanks:
I ride solo most of the time so I did this. Its a factory cup holder from a Land Rover Discover I got from Ebay for about $20. Holds huge cups and has an insert that comes out to go even bigger You have to be willing to drill 2 small screw holes into your shifter cover. Not sure how or if it will work in a 4WD but I am really happy with the results.
Yup it did fit fine on either side, didn't rub my leg and I am 6'1". I just decided to only do one on that side, again because I ride solo most of the time.
You might be able to fit one on either side, that is how the Disco cup holders are. Almost in the same place iirc, it's been awhile since I have driven/ridden in one.
Disco's have a much bigger area to play with.
The dash cupholders are just fine, i use them more than the console ones anyway and i have to shift you just have to occasionally put it in park. The console ones allow **** to flop side to side, as do the disco ones (mom had a disco). The dash ones have the tension on the container and they don't move. There is no easy or perfect solution as each have their pro's and cons.
No build thread or write-up..sorry, maybe down the road sometime. Bin busy with building my swing gate rear bumper, roof rack, etc. :)
I designed and built my own cup holder yesterday. Im going to install it a little later today. It works perfectly and will hold almost any size cup. It mounts in a perfect spot as well. I built it in around 3 hours and for $15. Ill post pictures when I install it.
I'm going to have a tan center console out of a 99' and the emergency brake handle for sale soon if you are interested.
WD
Some good ideas on here :)
I forgot that the site will only email me for the first reply and just now checked back in on this thread. Glad I came back to it, gives me some new directions to go.
Thanks guys!
