I only have the front rci skid right. Really easy to install and looks great. RCI's josh is great to work with. Drove up to his shop and he worked with me on what I need. I believe they also have most others beat on price.
Did you powder coat?
I'm sorry, did you saw "meow?"I did not. I did several coats of rustoleum and sealed them. There's a couple threads showing what the process is. I can't remember right meow.
TRDParts4U list ARB skid plates for 2010-2014.
ARB part number 5421110 for KDSS.
Part number 5421100 for non-KDSS equipped.
I just recently upgraded from a 2011 SR5 to a 2014 TE Premium.
I had a set on my 2011, and haven't had a chance to get the installed onto the new truck yet. Once I do, I will get some pictures put up on the site.
They should all fit from 2010 on. Frame, cross members, mounting holes have not changed.
ARB's skid plates are light duty, don't get them if you plan on rock crawling. The rear of the trans skid also interferes with the exhaust, so you will have to do some modding right off the bat.
[MENTION=77370]Gabex35[/MENTION], I'd like to see a pic of the damage. I have the RCI front skid, but have not been wheeling yet since I bought it. I do agree that the front looks a bit unsupported, but I would think 3/16" steel would be able to take some hits.
I have a full set of steel RCI skids on my 2014.
Unfortunately the front KDSS skid plate leaves a lot to be desired. I happened to bend it in Moab and it wasn't even on a hard impact. I don't care for the lack of support where the stock one mounts just behind the leading edge.
I think I would go with bud built if I had to do it all over again.
They should probably add something like this on Bud's, to brace it against the cross member.I don't have any photos and I'll be away from my truck for the week. It basically pushed up and back the front left corner (where the flat plane begins)
*Photo stolen from [MENTION=73024]Mick1[/MENTION]
So there's nothing between the front KDSS skid and the cross member that supports (the front of) the front diff? That should be addressed, as that is one of the most likely areas to encounter serious stress.Yup, that and the two beside it would be nice.
