aftermarket wheel questions...
bmw173
Couple of questions for aftermarket wheels for an '04 Sport:
Can anyone tell me where to get the 18" Enkei wheels that some on this forum have had installed prior to delivery?? These I like and I know they will work!
Can I get some input on the lug spacing, offset, and anything I may need to know, etc... so when I purchase a wheel set I know it will fit properly.
What happens to the tire pressure warning system when you put on a new set of wheels? I've read bad things on here about this but also see plenty of folks that have different wheels as well...
Thanks for any help!!
They installed mine when they came into port in Jacksonville, Florida. I would think you could get your dealership to order them for you. If all else fails, you could contact South East Toyota in Jacksonville, FL to see if you could get the wheels through them.
I have no idea about the offset of the wheels or any of the other specs. I also don't know what will happen to the tire pressure monitoring system. I would suspect it would be disabled if you change out the wheels.
Momo.75,
Thanks for the reply.
Actually, I called Southeast Toyota already trying to get these things and they basically told me they can't sell them to the general public, that they are a port installed option only, blah blah...
So I was bummed.
So does your TPM system work fine, or was this something that was added in '04?
I guess I need to figure out what I can put on that will work.
