Kip Dynamite
Is it possible to aim/adj. the headlights left or right???
I found the up and down adjusment, but did not see anything else. Thanks.
Yes. There are 2 bolts for adjusting -- the lower bolt (A) is the vertical adjustment, the upper bolt (B) is the horizontal adjustment. See this diagram:Kip Dynamite said:Is it possible to aim/adj. the headlights left or right???
For step 1b:HRunner said:Hi John, any pictures from the repair manual?
It's not easy to understand... (sorry I am not professional)
Based on the first diagram from step 1c, I'd presume at least the width of the truck and at least the height of the headlights.HRunner said:Sorry I think I am too dump~
How big is the paper do I need? And should I prepare the paper and draw the lines before I aligned the car with the paper?
If so, how to determine the H line? It's kinda confuse.
Please help... thanks~
jharris2 said:Based on the first diagram from step 1c, I'd presume at least the width of the truck and at least the height of the headlights.
Did you mean chalk?Koz said:If you find a flat level parking lot with a wall, you can use caulk to draw lines on the wall.
Koz said:If you find a flat level parking lot with a wall, you can use caulk to draw lines on the wall. I set mine up by parking 25 feet squared from the wall; draw a horizontal line the same height as the center of the headlight to the ground. Draw vertical lines centered from the distance between the centers of the two headlights. I adjust the lights until the beam
