air conditioning doesn't work at all
jbigman
I have a 2004 4 runner. On the display above the air conditioner where the est gas milage and ect is displayed went out. Also the air controls below display does not work. It wont blow any air hot or cold nothing happens. Is this a fuse or relay issue. Please someone help!!!! Thanks
Nobody on the message board can tell you that....Have you checked the fuses?
I have checked some and they have looked fine. I read something about a magnetic relay that causes some problems. I will check the rest tomorrow. The relay comes in thursday and I will see if that works. THANKS
Let us know if it turns out to be the relay.
For what it's worth, I'm not sure by your comment if you just did a visual check or not. If so, it may be best to check the fuses with a meter if you have one. If not, I'd pick up a cheap one and/or couple of spares and try swapping them in and out.
