Airbag light on (driver side)
Hi to bring this thread back to life.
07 4Runner v8 sr5
Driver Air bag light on.
Codes are b0101 and b1181 open in drivers squib and open in drivers squib (2nd step)
Ordered clock spring from eBay
Looks like an exact match.
Disconnected battery
Replaced cable smoothly
Hooked up battery
Cleared codes
Rescanned. Codes still there.
Bad cable? Something else ?
Reviving an old thread since I'm having the same issue. 2007 SR5 4x2 V6. Solid SRS light. It started out about 6 months ago and some days the light would come on and some days it would be off. Now it's been on permanently and the shop failed me on state inspection for having the light on (its questionable whether or not that is something that can cause a failure, but it is what it is). I have code B1181 open circuit is detected in the D squib (2nd step). I've checked all the cables under the seat and at the airbag module. Still on. I ordered a new clockspring assembly. Still on. At this point, I am left to assume it is the airbag itself which would be the most expensive part of the circuit to fail. Any advice or guidance appreciated.
2003 v8 SR5
Just had some steering rack work done. When I got it back it is throwing these same codes. Shop says they restrained steering wheel properly. I took it back and they wanted to change out the clock spring. (Steering wheel stereo controls, horn and Cruise don't work...blinker do) They ordered one and put it in and it and it didn't fix. They got a second one and that also didn't fix. Could it be ANYTHING else besides the clock spring?
As a side note, when we first got it back, it would immediately go into limp mode. I disconnected battery and it went away for a couple drives, but it happened again to my daughter on the road and she won't drive it until I figure it out. (No codes regarding this...)
Any insights would be appreciated.
2003 v8 SR5
Any update?
Just had this issue fixed at Toyota of Kirkland, WA. Here are the details:
2005 SR5 V6 212K miles
Found code B1181 (bad clock spring)
Labor 420
Parts 401
Misc 20
Tax 87
Total 928.40
2001ATL
