Airlift bags with lift?
yotaguy674
Hi all, I'm going to be installing some Airlift bags on my rig and was wondering if anyone else has done this? I have FJ springs in the rear which gave me about 1/2" of lift and plan on installing 1.5" spacers netting 2" of lift.
Now the question is: what kit do I get because of the added height? Anyone have any experience?
Yup, quite a few of us have these.
You cut the really expensive Toyota rubber coil overload/bump-stop to the size you need.
Your only talking .5 inch, in the coil.
I would think the standard ones will work.
I pulled the overload/bump-stop out and stuffed in these...
# AIR-46132, 5.38"x10.5"
I have the ext. SAW rear coils # 102-1575-195
I ran the Firestone airbags with FJ springs and Daystar spacers for a while and they worked great. I could load the hell out of my 4runner and 16’ trailer and didn’t have to worry about it squatting. Plus it was a whole lot more stable going down the road when loaded. I left the bags out when I swapped in some Icon rear coils but I still have them in case I need them again.
So you're saying buy the bags that are for my 4runner and cut off less of the bumpstop so they fit snug against it? I never thought of that lol
i still use the recommend bags for a stock setup, i think the fj uses the same bags as the 4runner. i use the firestone brand, i try keep mines at 10 psi since my trunk is constant weight with the battery and subs. they recommend keeping the bags at 5 psi.
Do you have a rear lift though?
Depending on how much you cut out.
If you look at the info J.A. posted you can see the installed bags.
I grabbed one of his pics as a reference.
You can see how the bag is not touching the cut-off bump-stop.
I didn't like that, to me it feels like as the suspension compresses and hits the bags, it kicks/rebounds off the bags. Making it bouncy.
With the bags filling the coil it reduced that sensation...slightly.
I run them flat with the valve stem cores removed now...for the last 4-5 months...not been towing anything for some time now.
Rides real nice.
Rides real nice.
Great pic. So cut the bump stop at the point where it touches the bag and not have the gap?
Yea, J.A. does a really good job on with write-ups...wish he would do a head gasket...
I was calling it the bump-stop, but the proper term would be 'coil-isolator' I guess.
In the directions it shows the isolator cut off at the top notch (of 3)...like J.A. shows.
In my kit it had a rubber puck that the bag sits on, between the axle and bag.
Also shows it in the directions I have. (pic 1) That's the only difference I see.
I did away with the isolator altogether, topped the coil with a 1/4" UHMW plastic disc that I cut out of a sheet to fit. (between the coils and the upper body mount). Then stuffed a bag in that filled the coil, after measuring the coil length. (pic 2 & 3)
The bottom of the coil isolator also made a nice winch cable stop. (pic 4)
I have a Daystar spacer lift (2.5” front; 1.5” rear) on my TRD Off Road and would like to add the Airlift system too.
Has anyone done this? I can’t seem to find a kit that will work for a 2017.
Any recommendations?
Same thing as the OP.
Your lift is from a 1.5" spacer on top of the coil?...using the stock coil spring.
Standard size bags should work.
Are not the 4th and 5th gen rear coils the same?
