AISIN Manual locking hubs
Singtoe
Looky looky , I just picked these up today.
2011-04-15_15-24-17_699.jpg~original
Now I have to get some bearings and seals...
Here are the step by step directions for the conversion to Manual locking hubs.
Remove wheel.
Here was my hub before the conversion. Note my wheel spacer.
AisinConversion3.jpg~original
My wheel spacer and stock hub.
AisinConversion4.jpg~original
Remove the wheel spacer, hub cap,cotter key, lock washer and 36mm nut.
AisinConversion5.jpg~original
Remove the 10mm and 12mm bolt that hold the brake line to the knuckle. Remove the 10mm bolt that hold the ABS speed sensor and pull sensor out.
Remove the Caliper and hang on the frame. I used a S hook from a bungee cord and hung it up.
Remove the Rotor
AisinConversion9.jpg~original
Remove the upper and the 4 lower ball joint bolts and remove Knuckle.
Put knuckle assembly in vise and remove bolts that hold splash shield.
AisinConversion11.jpg~original
Use a puller (I am using a 7-ton two jaw puller from sears, works great) and push the spindle out.
AisinConversion16.jpg~original
Remove the giant E-clip that holds the bearing in the knuckle and press out knuckle.
AisinConversion17.jpg~original
Press in a new bearing, install your giant e-clip, splash shield, and outer seal (I had bought new ones but the old ones were good enough to re use)
AisinConversion20.jpg~original
Now you can press in the Manual lock spindle into you knuckle. I pressed it back together and brought the knuck back to the vise for further assembly.
AisinConversion21.jpg~original
Now you install the ABS Hall generator.
AisinConversion23.jpg~original
Now the locking nut. Tighten it down to 204 foot pounds. I used the 4 pin tool.
AisinConversion25.jpg~original
asisinlock4.jpg~original
Stake the lock nut using a hammer and punch then Install inner seal.
AisinConversion27.jpg~original
Pull the old CV axle out and install the manual locking axles. Grease the axle generously.
AisinConversion28.jpg~original
Install the knuckle assembly back onto your upper and lower ball joints. I install the broached washer along with a circle clip.
AisinConversion29.jpg~original
Bolt in the Aisin Locker body and the 12mm bolt that locks the Aisin Cog to the axle.
AisinConversion30.jpg~original
Bolt Aisin Outer body to the hub using 6 - 10mm bolts. These bolts are marked 7, so they are quite weak, do not over tighten.
AisinConversion31.jpg~original
Bolt Spacer back on. 83 foot pounds and use locktite to prevent the spacers from loosening up.
AisinConversion32.jpg~original
Bolt wheel back on.
AisinConversion34.jpg~original
Back to OEM look. with the hub cap installed.
Sorry but I had to cut some photos out. The Forum only allows 20 photographs.
I just bought the tool off E-bay to take the nut off the back of the hub.
$(KGrHqF,!h8E2I+UCyWsBNn5lTMEzg~~0_12.JPG~original
Now to order some bearings and seals...
It is cleaning up very well...
2011-04-15_21-40-09_422.jpg~original
2011-04-15_21-41-51_752.jpg~original
2011-04-15_21-44-03_110.jpg~original
2011-04-15_21-45-41_458.jpg~original
Update: After waiting almost a month to get the tool from ebay- Actually the seller was a jerking me around, so i had to file a complaint with ebay and got my money back. I then bought another tool from ebay (different seller) and it came like 4 days later.
I was able to take the lock nut off but what a pain in the butt to push the spindle out.
I will take some pictures of the process today.
Subscribed lol, will this work on all models(ie limited).. Im really not a fan of my setup, would love to have that as my next mod.
I got the tool and broke the locking nut off. Easy as pie.
OK. Pushing out the spindle is the biggest pain in the Butt on our trucks. OMG!
I found out the bearings in these hubs weren't the original. They were made by timkin. I think they were tighter then the original.
The hubs with oem bearings came out of my truck so much easier.
I have a 20 ton press but the spindle face is significantly wider then the knuckle housing so i could not use it. The FSM say that there is a special tool but all it looked like to me, was that it looked similar to a 2 arm puller.
So that is what I used.
asisinlock6.jpg~original
So about my messy work bench. Not enough time in the day.
asisinlock2.jpg~original
After about 45 minutes of messing around. She finally came out.
asisinlock5.jpg~original
You got the axle hub out with a puller? When I did mine on the Tacoma it took a 40 ton press to get it out....You must have some massive arms and strength...LOL Nice job...
I'm gonna do my Runner when I get the time...I have the lock-outs just gotta buy some axle hubs , bearings and seals.I am going to keep my ABS ring so that stupid light won't come on...
It will work.You can use your ABS ring and keep your ABS system working. I have done this on 3 Tacomas....
Sweet! With the multi-mode system what has to be done to the electrical system that goes along with it? I'm debating on doing this or just switching out everything and ditching the whole system all together.
You don't have to anything with the electric system or the stock ADD system on the front axle. I am installing this on my Limited and it will work fine. The only issue is that if the hubs are unlock, the AWD button will cease to function - Actually, the 4runner will not even drive, all the drive power will go to the front diff and just spin around.
All that is needed are the manual hubs off the base model Tacoma.
I still have the same tool I had to buy to complete my 4x4 swap....just sitting in the tool box ever since but it was money well spent.
4x2.jpg~original
Awaiting press work
hubs-swap.jpg~original
manual3.jpg~original
absring.jpg~original
unfortunately I couldn't find a set of Aisin hubs at the time and had to settle with these. Also had to sell my Ivan Stewart wheels.
finished2.jpg~original
i would do this to my tundra. used to have kits for it, but they were upwards of 1k and now the comapany that makes the kits is out of business.
